Based on the intel support matrix, the module to be used is AXXTPME5. (It's hw specs indicates that it is version 1.2)
Also S2600WP server boards spec indicate that TPM is supported but couldn't find it in the compatibility matrix:
http://www.intel.com/support/motherboards/server/sb/CS-032301.htm Intel® Trusted Platform Module (Intel® TPM) compatibility matrix
It is correct; currently the Trusted Platform Module modules that we offered are version 1.2. The Intel® Server Board S2600WP does not offer support for TPM.
Thanks for the response. Can you please clarify if there are any other recommended TPM 2.0 modules available for S2600WZ? If not, when will this be available?
Intel® is only offering TPM rev 1.2 for this board. As of today, there are is no announcement of implementing TPM rev 2.0 with this system or any other systems.
