Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
MFSYS25+VLAN+VMWARE
Hello, sorry for my English. Please help me, I'm not so customizable.
Objective: Connect the external port to the virtual machine.
I use this article: http://www.intel.com/support/motherboards/server/sb/CS-031599.htm# 3-Many-One http://www.intel.com/support/motherboards/server/sb/CS-031599.htm# 3-Many-One
1. Сreated a VLAN
2. Changed the port PVID (Ext.1)
3. Here is the VLAN 1 - Default
4. Here is the VLAN 11 - my
5. Then I added the VM Network (VMNetwork to Web)
6. The properties changed VM network.
What am I doing wrong?
Daniel_O_Intel
Do you have VLAN 11 set to tagged, or untagged, inside the virtual switch? It should be tagging packets.
If you are not going to have more than one VLAN on that virtual switch, you could also change everything over to untagged.
