Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5076 Discussions
Malibou Lake Software build error
hyeongilee99
Hi, I'm working on the build guide in document 816867. I'm almost done with the build, but when I build with bitbake core-image-sato, I get the following error:
ERROR: zlib-native-1.2.13-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/intel/yocto_build/OS/LINUX/YOCTO/poky/scripts/native-intercept:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/scripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/usr/bin/x86_64-linux:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/usr/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/bitbake/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/hosttools"; export HOME="/home/intel"; /usr/bin/env wget -w 10 -c -t 5 --waitretry=10 -T 360 -nv --passive-ftp --no-check-certificate --hsts-file=/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/.wget-hsts -P /home/intel/yocto_build/OS/LINUX/YOCTO/build/downloads 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers' --progress=dot -v failed with exit code 8, no output ERROR: zlib-native-1.2.13-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers') ERROR: Logfile of failure stored in: /home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/temp/log.do_fetch.14754 ERROR: Task (virtual:native:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/../meta-intel-automotive/recipes-core/zlib/zlib_1.2.13.bb:do_fetch) failed with exit code '1' WARNING: lib32-zlib-1.2.13-r0 do_fetch: Failed to fetch URL https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers, attempting MIRRORS if available ERROR: lib32-zlib-1.2.13-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/scripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/usr/bin/i686-pokymllib32-linux:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/lib32-recipe-sysroot/usr/bin/crossscripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/usr/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/bitbake/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/hosttools"; export HOME="/home/intel"; /usr/bin/env wget -w 10 -c -t 5 --waitretry=10 -T 360 -nv --passive-ftp --no-check-certificate --hsts-file=/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/.wget-hsts -P /home/intel/yocto_build/OS/LINUX/YOCTO/build/downloads 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers' --progress=dot -v failed with exit code 8, no output ERROR: lib32-zlib-1.2.13-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers') ERROR: Logfile of failure stored in: /home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/temp/log.do_fetch.14796 ERROR: Task (virtual:multilib:lib32:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/../meta-intel-automotive/recipes-core/zlib/zlib_1.2.13.bb:do_fetch) failed with exit code '1' WARNING: zlib-1.2.13-r0 do_fetch: Failed to fetch URL https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers, attempting MIRRORS if available ERROR: zlib-1.2.13-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/scripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/usr/bin/x86_64-poky-linux:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot/usr/bin/crossscripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/usr/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/bitbake/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/hosttools"; export HOME="/home/intel"; /usr/bin/env wget -w 10 -c -t 5 --waitretry=10 -T 360 -nv --passive-ftp --no-check-certificate --hsts-file=/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/.wget-hsts -P /home/intel/yocto_build/OS/LINUX/YOCTO/build/downloads 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers' --progress=dot -v failed with exit code 8, no output ERROR: zlib-1.2.13-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers') ERROR: Logfile of failure stored in: /home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/temp/log.do_fetch.14773 ERROR: Task (/home/intel/yocto_build/OS/LINUX/YOCTO/poky/../meta-intel-automotive/recipes-core/zlib/zlib_1.2.13.bb:do_fetch) failed with exit code '1'
I think the file in the URL probably doesn't exist. Thank you.
Vipin_S_Intel
Hi Hyeongi, could you please share the below details with us?
  • Operating system with its build version.
  • Exact name and version of the of Intel® Toolkit.
  • Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
  • Screenshot of the error (if possible)
To assist you further, we would require these details.
hyeongilee99
    • MBL_2417_EXTERNAL
    • There is no installed Intel Parallel Studio XE or Intel® oneAPI. I couldn't find any instructions in the documentation to pre-install that software.
    • Screenshots and log files are attached.
(Virus scan in progress ...)
Vipin_S_Intel
Hi Hyeongi,  thank you for sharing the required details. We would like to inform you that we are routing your query to the dedicated team for further assistance.
BoonBengT_Intel
Hi @hyeongilee99,
Thank you for posting in Intel community forum and hope all is well.
Noted on the environment used, quick clarification, are you using a FPGA or based on the screenshot error, you are just trying to build the mention yocto project within your machine CPU?
Or perhaps you can let us know what are the hardware you are using for this build.
Hope to hear from you soon.
BB
hyeongilee99
I'm trying to build on my computer based on the screenshot. CPU information is as follows.
intel@4dd25ff3da7a:~$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 85
model name : Intel(R) Xeon(R) Gold 6234 CPU @ 3.30GHz
stepping : 7
microcode : 0x5003605
cpu MHz : 3300.000
cache size : 25344 KB
physical id : 0
siblings : 16
core id : 8
cpu cores : 8
apicid : 16
initial apicid : 16
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb cat_l3 cdp_l3 invpcid_single intel_ppin ssbd mba ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm mpx rdt_a avx512f avx512dq rdseed adx smap clflushopt clwb intel_pt avx512cd avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local dtherm ida arat pln pts hwp hwp_act_window hwp_epp hwp_pkg_req pku ospke avx512_vnni md_clear flush_l1d arch_capabilities
vmx flags : vnmi preemption_timer posted_intr invvpid ept_x_only ept_ad ept_1gb flexpriority apicv tsc_offset vtpr mtf vapic ept vpid unrestricted_guest vapic_reg vid ple shadow_vmcs pml ept_mode_based_exec tsc_scaling
bugs : apic_c1e spectre_v1 spectre_v2 spec_store_bypass swapgs taa itlb_multihit mmio_stale_data retbleed eibrs_pbrsb gds bhi
bogomips : 6600.00
clflush size : 64
cache_alignment : 64
address sizes : 46 bits physical, 48 bits virtual
power management:
Thanks you.
Simon-Intel
Hi hyeongilee99,
You have reached the server support team.
As your query is related to a build error with bitbake core-image-sato while using Malibu Lake Software, please post your query on the community forum below:
Software Development Tools
Simon
