Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
May be you can help us we have QSV server with
VNiko2
bios S1200RP.86B.03.04.0002.110820161604 CPU Intel(R) Xeon(R) CPU E3-1276 v3 @ 3.60GHz RAM 2x ChannelA-DIMM1 8192 DDR3 1600 Micron 9876543210 1820287218KSF1G72AZ-1G6P1 and we have problem with CATERRProcessorreports it has been asserted - Deasserted
Hello Valerijs,
Could you please let me know your motherboard model?
Amy C.
VNiko2
Manufacturing Date :2015-08-06 07:49
Manufacturer :Intel CorporationProduct
Serial Number:BQRP53100721
Part/Model Number :G62254-407FRU
File ID :FRU Ver 1.00
/thread/115235 Valerijs, I will move your thread to the Servers department in order to further assistance with this matter.
Amy C.
Hello Valerijs,
Thank you for contacting Intel Customer Support.
I understand that you need assistance with your Intel® Server Board S1200RP.
Please help us providing more information in order to narrow down your problem:
1. Detailed issue description:
2. Are you receiving an error message? If so please provide the exact wording of the error message and when you are receiving the error message.
Sergio S.
Intel Server board support.
VNiko2
Hello! Thanks for answer! we have 11 servers whey work in linux Centos 7 with enabled QSV support. Its a multicast transcoding servers mpeg2----> h264_qsv transcodin to multicast ...
Servers
CPU model name : Intel(R) Xeon(R) CPU E3-1276 v3 @ 3.60GHz
Board S1200RP firmware S1200RP.86B.03.04.0002.110820161604
Server with board Intel Server System R1304RPMSHOR
its a random problem
Hello Valerijs,
Can you please provide us a copy of the syslogs? If you need assistance on how to get this information, please check https://www.intel.com/content/www/us/en/support/server-products/server-boards/000006960.html here
Also, please let us know the troubleshooting steps that you have tried in order to resolve this problem.
We will look forward for your response.
Sergio S.
We appreciate the additional information, can you please let us know the troubleshooting done in order to resolve this problem? Did you try different components?
Regards.
Sergio S.
VNiko2
yes we try different componets but we have this error CATERR on all our 10 servers (componets are same) this problem not early but random .... on same servers only one problem per 2 mounth on same early
Hello
Thank you for the additional information, we are going to check on the logs that you sent and will let you know as soon we find a resolution.
Regards.
Hello Valerij,
We just sent you a private message requesting additional information, please check your inbox.
Regards.
Hello Valerijs,
We are following up your case and we would like to know if you need further assistance also, please let us know if you are seeing any issue or any business impact by having the errors in the SEL
Regards.
Sergio S.
Hello https://c.na37.visual.force.com/apex/JiveCommunityReply?msgID=483567&contenID=621783&isReplyToMainThread=undefined Valerijs,
We are following up your case and we would like to know if you need further assistance.
Regards.
Sergio S.
VNiko2
Yes because we problem still here ! today we have a new reboots
Hello, Valerijs,
I am going to review again the logs and return with a workaround if it is available.
Mike C
VNiko2
Hello!!! we want get a 3 new transcoders for IPTV QSV servers we wont a best configuration ! Can you get some parametrs
may be
Intel® Xeon® Processor E3-1285 v6
we need compateble board and ather componets
and somthink low cost v5
for compatabilites with
Intel Media Server Studio 2017 R2
We recommend contacting an https://locate.intel.com/ Intel(R) Authorized Distributor near your area:
You can also check https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html here for more information.
Sergio S.
