I have a problem similar to this thread: http://communities.intel.com/message/153407 http://communities.intel.com/message/153407
My config:
Intel SS4000-E
Firmware: fs-bc - 1.4-b710
4 x Seagate ST3500320NS 500 GB drives, RAID 5
One of these disks broke down yesterday. I replaced it by an identical disk spare. The rebuilding process started and worked during about 24 hours.
Now it is finished but I cannot access my data. The storage status indicates Shared Folders : NOT READY.
In ssh mode I cannot see the NASDisk-00004 folder where my data were stored.
Something were wrong during the rebuilding process if I understand the system log page:
May 7 17:11:16IStorage synchronization completedMay 7 11:12:49IAdministrator logged in from IP address [192.168.1.102 ].May 7 06:05:14WA disk error has occurred. The storage system is now operating in degraded mode.May 7 00:01:20IDate/time adjusted to time server [pool.ntp.org ]May 6 14:14:55IStorage synchronizingMay 6 14:13:54IDisk [3 ] has beed added to current storage configurationNethertheless the "Advanced : Disks" page displays Disk configuration : RAID 5 (Normal)
I am completely lost and at this stage I need a serious HELP!
Thank you in advance.
Tryphon,
The "Advanced : Disks" page displays Disk configuration : RAID 5 (Normal) because the Storage synchronization completed.
From your system log page it looks like a disk error occured during the synchronization. The failure could be a bad sector on a second disk that contained parity or data for the array. That would mean you had a two drive failure (the original disk and the second disk with the disk error). Unfortunately a two disk failure in a RAID 5 array is unrecoverable.
This is after the fact, but the first thing you should do, if you can, at a RAID failure, is to backup your data. For more information, see our support article on http://www.intel.com/support/motherboards/server/sb/CS-025645.htm Planning for the worst case: the importance of a backup solution.
John
I have a backup of a big part of my data. In fact I lost the data in transit, recorded on the SS4000 for a short time before definitive storage (because of lack of space on my computer). Bad luck, in the meanwhile the disk 3 failed!
I understand I have a second disk with bad sector. Of course with two errors my data cannot be recovered.
I have the faulty disk (number 3). It makes a clic noise at starting and finally fails to start. Maybe a mecanical problem.
Suppose one moment that disk 3 is repaired without loss of data: if I replace this disk 3 at position 3 of the SS4000-E, the system come back to its previous state, that is to say one error somewhere on disk 1, 2 or 4. But in RAID 5 configuration, data are available with only one error. In this case, how will react the SS4000-E viewing the original disk 3 (readable)? Is it a way to retrieve my data (if disk 3 is repaired)?
I want to hope ...
Thank you.
