Hello there,
I had a lovely working server until today, I wanted to add a internal ssd into the case so I had to get the power supply for it. There is a OSD connector there for power so I found a thread on how to get a cable ffor this connector as there not available to buy now. I followed this guide to make up my cable
/thread/36313 https://communities.intel.com/thread/36313
In hind sight I should of got the multimeter out and checked the voltages myself as its obvious something has short circuited.
Upon plugging in a hard drive the server turned off with a bunch of beeps, I have tried to power on the server several times with the same set of beeps. I had the reduntant power supply disconnected at the time and that does not help either.
I am able to access the BMC and gather the sensor reading and shows the following messages
Pwr Unit Status
reports there has been a soft power control failure reports the power unit has suffered a failure
Critical
0x0060
Pwr Unit Redund
reports redundancy has been lost reports redundancy has been lost and there are insufficient resources to maintain normal operation
Critical
0x0022
PS1 Status
reports the power supply's presence has been detected reports the power supply has suffered a failure reports a predictive failure has been detected for the power supply
Critical
0x0007
PS2 Status
reports the power supply's presence has been detected reports the power supply's input (AC/DC) has been lost
Critical
0x0009
Is there a reset procedure I can do or have I fried the motherboard?
Any help would be appreciated.
Craig Dabbs
We understand that trying to build the cable something went wrong with the voltages, in this case since the power supply connectors are built into the board this shortcut may affect the board itself. What you can try as the last course of action to make sure the board is not working properly is set the bios defaults with the jumper J6D1 and also trying with a different power supply besides the ones you are using.
You will find the jumper location on page 92 of the following document:
http://download.intel.com/support/motherboards/server/sb/s2600gzgl_tps_r2_4.pdf http://download.intel.com/support/motherboards/server/sb/s2600gzgl_tps_r2_4.pdf
Other than that if still doesn't work the board it's already damaged.
Thanks for replying,
Hopefully some of the components made it out alive.
Hopefully it will be just the board, but let us know how it goes after trying the steps suggested or if you need further assistance.
Esteban V.
Following up on this matter we would like to know how did it go after trying the steps suggested.
Esteban V.
