Hi. I have Intel server system SR2600URSATAR. I'm install Intel Network Card Intel PRO 1000 PT QUAD PORT in riser. I'm not see device in operation system. I have latest BIOS. This network card work correct in my desktop. Other PCI-E card also correct work in riser. Please help me resolve it problem.
Most likely you have one of the older, full-height adapters that are not compatible with newer PCI Express slots. Check for a product code on the adapter. The older, full-height adapters had these codes:
EXPI9404PTG1P20
EXPI9404PT
EXPI9404PTBLK
If your adapter has one of the product codes listed above, you will not be able to get the adapter to work.
Newer versions of the adapter called the Intel® PRO/1000 PT Quad Port Low Profile Server Adapter with these codes do not have the incompatibility issue with newer PCI Express slots:
EXPI9404PTLBLK
EXPI9404PTL
When I looked at the http://serverconfigurator.intel.com/sctthol.aspx?search=Server+System+SR2600URSATAR Server Configurator Tool, I did not see the older, full-height adapter listed, so the most likely solution is to use a newer network adapter.
Mark
EXPI9404PTG1P20
EXPI9404PT
EXPI9404PTBLK
EXPI9404PTLBLK
EXPI9404PTL
Mark
