Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4917 Discussions
R2312GL4GS & RES2CV240 & RMSCB040
GTobi1
New Contributor II
Is it possible to use an RMSCB040 RAID6 module in conjunction with a SAS expander (either RES2CV240 or RES2SV240) to run up to 12 drives in a R2312GL4GS server system.
Will a RES2CV240 physically fit in a R2312GL4GS, is there a molex connector to power it and crucially is it a supported configuration.
I know a RS2WG160 controller will work but I'm looking for a less expensive solution.
GT
Edward_Z_Intel
Yes it will work. The expander card will be installed in one of the PCIe risers, and power is supplied through the PCIe connector.
Edward_Z_Intel
GTobi1
New Contributor II
Thank you..
