Im planning to build a little homeserver/nas with a WX58BP Board running 4x3tb in an raid5. The problem is that the BIOS recognizes the 3tb drives as 801gb drives, but in Windows i can see the whole capacity.
I googled a lot and found out that the ich10 v 10.1 cant handle drives with 3tb, but the latest BIOS update v042 for my Mainboard includes only v10.1 of the storage controller. Is there any possibility to get a newer Version of the ich10 into my BIOS?
Best regards Joshua
We regret to inform you that the issue you are experiencing is a hardware limitation for the board since is a mature product.
No, Intel BIOS is digital-signed and OpRoms cannot be swapped by public tools. Probably, you can install Windows onto dedicated HDD and, with latest RST drivers, create and use RAID as data storage volume from Windows.
I hoped that i could use ist without windows software raid...
Thank you for your quick answer.
Try to create RAID in Windows RST interface. RAID OpRom checks only headers of HDDs at time of boot, so your RAID may work (although not bootable).
I have moved this post to the appropriate department
Allan.
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
