Hello Mr. Klaus,
Thank you for contacting Intel Technical Support for Intel® Server Products. Regarding your question, "RS2BL040 unable to save power savings settings".
First, let's verify some information:
- What windows version?
- Are you running the RAID Web Console locally or remotely?
- And what model of HDD are you using – SSD or 3.5 or 2.5 SATA HD?
If there is anything else we can help please feel free to ask.
Henry A.
Intel Enterprise Support
Windows server 2008 R2. Latest webconsole, latest firmware, latest driver.
500GB 3.5" WD RE4
Console is run locally
Thank you for the information.
And if I see right you running RAID 5 plus one Hot Spare HDD for a total of 4 HDD
This is so I can recreate the information
Yes, that is correct. 3 drive raid 5 and 1 global hotspare.
Klaus
Hello Mr. Klaus,
Thank you for information. I going to recreate your setup and as soon as I have some information I will send it to you.
Henry A.
Hello Mr. Klaus,
After recreating the problem, we are also having the same errors. Checking with engineering team to see if this is related to the card or the drivers or etc. Please allow us some time on this.
Henry A.
Hello Mr. Klaus,
Thank you for your patience. We have been able to recreate the problem. But after rebooting the options were saved. We are checking with Engineering on this issue. I will get back with you as soon as we have some information.
Henry A.
Hello Mr. Klaus,
Henry A.
Hello Mr. Klaus,
Henry A.
Hello Mr. Klaus,
Thank you for your patience. We have been able to recreate the problem. But we require a little more information. Could you please send us the IRF and TTY logs.
Henry A.
Hello Mr. Klaus,
In order to forward this issue to engineering we will require you to provide us with the IRF and TTY logs.
Jose H.
