hi there, having troubles building this driver under sles11-sp2, and it look like raid-console need this version to work properly:
rpm -ivh dkms-2.0.22.0-1.noarch.rpm
rpm -ivh ir3_sas-v00.00.06.12-1.noarch.rpm
_gives error, so:
patch < patches/sles11-sp1.patch
dkms build -m megaraid_sas -v v00.00.06.12
KMS make.log for megaraid_sas-v00.00.06.12 for kernel 3.0.13-0.27-xen (x86_64)
Tue Jul 3 14:55:45 CEST 2012
make: Entering directory `/usr/src/linux-3.0.13-0.27-obj/x86_64/xen'
make -C ../../../linux-3.0.13-0.27 O=/usr/src/linux-3.0.13-0.27-obj/x86_64/xen/. modules
Updating /var/lib/dkms/megaraid_sas/v00.00.06.12/build/Makefile.xen
CC [M] /var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.o
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:44:28: error: linux/smp_lock.h: No such file or directory
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:3233: warning: initialization from incompatible pointer typ
e
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:5194: error: unknown field 'owner' specified in initializer
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:5194: warning: excess elements in struct initializer
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:5194: warning: (near initialization for 'sysfs_max_sectors_
attr.attr')
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:5197: warning: initialization from incompatible pointer typ
e
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c: In function 'megasas_mgmt_open':
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:5994: error: implicit declaration of function 'cycle_kernel
_lock'
make[3]: *** [/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.o] Error 1
make[2]: *** [_module_/var/lib/dkms/megaraid_sas/v00.00.06.12/build] Error 2
make[1]: *** [sub-make] Error 2
make: *** [all] Error 2
make: Leaving directory `/usr/src/linux-3.0.13-0.27-obj/x86_64/xen'
,need a help building this...
