Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4550 Discussions
Raid - Media Errors problem
I have a S5000VSA server running 4HDDs in a RAID 10 configuration;
SATA Slot 0 & 1 are for Span 0
and
SATA Slots 2 & 3 are for Span 1
I noticed the properties of the physical Disks 0 & 1 were showing media errors (and a consistency check shows the same)
There are a 11 in total here is a sample of the events being recorded;
ID = 33
SEQUENCE NUMBER = 36
TIME = 18-09-2009 15:48:06
LOCALIZED MESSAGE = Controller ID: 0 Consistency Check detected uncorrectable multiple medium errors: ( PD 0:1 Location 0x2ef9c5 VD 0)
ID = 32
SEQUENCE NUMBER = 35
LOCALIZED MESSAGE = Controller ID: 0 Consistency Check detected uncorrectable multiple medium errors: ( PD 0 Location 0x2ef9c5 VD 0)
I removed the Slot 0 & 1 drives, replacing them with new ones and let them rebuild. However I am still seeing exactly the same errors on these new ones;
ID = 154
SEQUENCE NUMBER = 182
TIME = 19-09-2009 22:35:11
ID = 153
SEQUENCE NUMBER = 181
Any ideas what I can do next to correct this?
Thanks for any help
Daniel_O_Intel
Strange - it's almost like it kept the old errors, even though there's new drives in place.
Can you force a consistency scan from within the RAID console?
Yes the consitency scans in my first post were from the console.
To confirm the errors on the old drives I ran Spintite which confirmed that each of the removed HDD are indeed having difficulties. One is in fact completely dead now.
Daniel_O_Intel
Does Spintite show any problems with the new drives you put in?
