Hi All
I have a S1200BTL powered server that I have installed a RMM4 module. When entering the bios, I can set and IP address for the BMC and RMM4, but the RMM4 says "Not present".
I have tried removing the main module and installing the RMM4Lite (the tiny little chip) but it still says "not present".
Is there anything else I need to do? I have followed the installation documentation very closely and it seems all I need to do is install the module and it will autodetect, then assign an IP in the bios.
Any help would be appreciated.
Jono
You have to have the RMM4Lite installed, and do a firmware update, before it will show up in the BIOS, if I recall correctly.
I flashed the Bios with the latest version while the RMM4 module was installed, and it still says that it is not present.
Do I need to have both the RMM4 module and RMM4 Lite modules installed at the same time?
I would install both prior to flashing.
The RMMlite is all than "should" be needed, but better to have the hardware fully installed.
Did you flash the BMC code? RMM firmware resides in this piece of the code.
II've updated to the latest bios again but it is still showing up as "not present".
Any more ideas? I really need to get this working.
Might be a faulty unit. We had something similar on a hosted box once and they replaced the RMM.
Did you ever solve this?. I have a S2600CP board that says there's no BMC installed but at the same time an RMM4 that can be accessed vis network and doesn't receive information from BIOS.
