Hi all
I have two workstations with S1200V3RPM board and XEON E3 1265LV3 Processor. One runs Win 8.1 on this machine, Intel update found a driver for the P4600 graphics of the XEON.
The other machine runs Windows 7 (need Win 7 cannot switch to 8.1). On this machine Windows update does NOT find any graphics driver for the P4600. I tried installing the driver for 4600 driver, but I get an error message on installation.
Can anyone tell me where I can find the correct driver for P4600 and Windows 7 64bit?
Thanks and regards
Rudi
- Tags:
- Drivers
The driver was just posted: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23700 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23700. The link should be live in a day or two.
Hi Edward
thanks for the link. I tried to install the driver, but got the error message "This computer does not meet the minimum requirements for installing the software".
My configuration is:
- S1200V3RPM board
- XEON E3 1265L V3 processor
- Win 7 Home Premium 64bit
Reg
Rudi
I have found the source of the problem:
The driver file Edward indicated had in its igdlhc64.inf a DevID of 041A, whereas my System lists Ven 8086 and Dev 040A. I modified the inf file to reflect the correct Dev code and presto, the driver installed. During installation it correctly identified the P4600 graphics HW.
Encouraged by this, I located the latest graphics driver at http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/23714/a08/win6... Download Center and made the same modification. This driver installed without a problem as well (except for the message that it is not signed).
So this problem is solved. Thanks, Edward for pointing me in the right direction.
Still unsolved is the problem that the driver does not support audio passthrough on the displayport./message/225196# 225196 https://communities.intel.com/message/225196# 225196
