Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5074 Discussions
S1200V3RPO set PCIe slot6 to GEN3x8
SBraz
Dear all,
anybody knows how to set the PCIe slot6 of a S1200V3RPO server to GEN3x8?
By default it's GEN2x16, but on the user manual it's written that it could be switched to GEN3x8, although there are no specifications on how to do that.
Thank you and best regards.
David_A_Intel
The speed is going to vary based upon the fact if there is a card installed in slot 5 or not. If there isn't; Slot 6 should be able to run a PCI Express* Gen 3 x8.
SBraz
Dear David,
thank you for your answer.
S1200V3RPO has only one PCIe slot, which is slot # 6.
Indeed if I connect a PCIe GEN3x16 device it's trained only at GEN2x8.
I am in contact with INTEL Customer support for this.
I'll let you know their answer.
