Server Products
4799 Discussions
S2600WF0 SysCfg : set Fan PWM Offset
SF_
we've got a couple of hundreds of Intel S2600WF0 servers. BIOS/ME/BMC/FRUSDR are all the latest:
BIOS Version Information:
Primary BIOS Version:... SE5C620.86B.00.01.0014.070920180847
Secondary BIOS Version:. SE5C620.86B.00.01.0014.070920180847
BIOS Boot Region:....... Primary Boot
BMC Firmware Version:
Op Code:........... 1.60.56383BEF
ME Firmware Version:.. 04.00.04.340
SDR Version:.......... SDR Package 1.60
Baseboard Information:
Base Board ID:..... S2600WF0
Asset Tag Name:.... Base Board Asset Tag
System Information:
Manufacturer Name:. Intel Corporation
Product Name:...... S2600WF0
Version Number:.... ..
Chassis Information:
Manufacturer Name:. ...............................
Chassis Type:...... Rack Mount Chassis
Asset Tag Name:.... ....................
Also have the latest SysCfg: System Configuration Utility Version 14.1 Build 21
OS: Debian 9 'Stretch' 64bit
We'd like to be able to change the Fan PWM Offset using the SysCfg utility, but it's not working:
$ sudo /usr/bin/syscfg/syscfg /bcs "" "Fan PWM Offset" 100
BIOS Variable 'Fan PWM Offset' not found
However, the fan profile can be changed:
$ sudo /usr/bin/syscfg/syscfg /bcs "" "Set fan profile" 1
Successfully Completed
If I save all the settings with sudo /usr/bin/syscfg/syscfg /s /f /b, then the resulting syscfg.INI file doesn't have anything about Fan PWM Offset, it only has the Set Fan Profile in the System Acoustic and Performance Configuration group:
[BIOS::Advanced::USB Configuration]
Device Reset Timeout=20 seconds ;Options: 10 seconds=00: 20 seconds=01: 30 seconds=02: 40 seconds=03
[BIOS::Advanced::System Acoustic and Performance Configuration]
Set Fan Profile=Performance ;Options: Performance=01: Acoustic=02
[BIOS::Security]
Front Panel Lockout=Disabled ;Options: Disabled=00: Enabled=01
Tried to insert Fan PWM Offset=100 into the [BIOS::Advanced::System Acoustic and Performance Configuration] group and the restore the syscfg.INI file with the restore option of syscfg. The utility said the restore was successful, but the Fan PWM Offset change didn't effect, the BIOS showed the old value (0). We'd like to avoid manually changing this on hundreds of servers obviously.
Also tried to downgrade BIOS/BMC to the previous version. With the old BIOS/BMC syscfg was able read the Fan PWM Offset value (i.e. sudo /usr/bin/syscfg/syscfg /d biossettings "Fan PWM Offset" was working), but unable to write it.
According to the release notes of latest BIOS the Fan PWM Offset should work with SysCfg: https://downloadmirror.intel.com/28252/eng/Release%20Notes.txt https://downloadmirror.intel.com/28252/eng/Release%20Notes.txt
See: HSD-ES:1504762466, BIOS Change for # CCB 2083[Syscfg tool]Add option to configure fan pwm offset in syscfg
How to change the fan pwm offset? Please help!
Hello Szabolcsf,
Are you getting loud fans after you perform the BIOS update?
Additionally, as first troubleshooting suggestion, please try to perform a BIOS recovery downgrade to the previous BIOS https://downloadcenter.intel.com/download/27632/Intel-Server-Board-S2600WF-Family-BIOS-and-Firmware-Update-Package-for-UEFI-?product=89015 version.
After performing the BIOS recovery, please try to change the PWM offset again,
In case you have any additional questions, please check the https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/Intel_Syscfg_UserGuide_V1.02.pdf user guide.
Sergio S.
SF_
Hi Sergio,
thanks for trying to help. When upgrading to the latest BIOS, yes, the fans are loud. But only for ~2 minutes, until the new BIOS/ME/FRUSDR is loaded. After that everything is normal. This is not the reason why we want to change the offset setting. We are doing CPU intensive computing and PSU2 is overheating (this is closer to the processors). PSU2 temperature is frequently hitting 62C which makes the servers throttle. We've done some experiments and determined that if we use Set Fan Profile=Performance and Fan PWM Offset=100 then PSU2 temperature drops by ~5-10C and the servers won't throttle. Now we just need to deploy this to a couple of hundreds of servers without manually entering the BIOS on each.
Regarding the previous BIOS and firmware versions: as I wrote, only reading the Fan PWM Offset works, but writing doesn't. Let me clarify what I mean:
$ sudo /usr/bin/syscfg/syscfg /d biossettings "Fan PWM Offset"
Fan PWM Offset
Current Value : 0
Possible Values
100 : Max
0 : Min
1 : Step
~$ sudo /usr/bin/syscfg/syscfg /bcs "" "Fan pwm offset" 1
Error: Change BIOS setting failed. It may be caused by invalid data in the switch parameters.
~$ sudo /usr/bin/syscfg/syscfg /bcs "" "Fan pwm offset" 0
~$ sudo /usr/bin/syscfg/syscfg /bcs "" "Fan pwm offset" 100
~$ sudo /usr/bin/syscfg/syscfg /bcs group "system acoustic and performance configuration" "Fan pwm offset" 100
Invalid invocation or entered password does not match with current password.
$ sudo /usr/bin/flashupdt/flashupdt -i
One Boot Flash Update Utility Version 14.1 Build 17
Copyright (c) 2018 Intel Corporation
System BIOS and FW Versions
Primary BIOS Version:... SE5C620.86B.00.01.0013.030920180427
Secondary BIOS Version:. SE5C620.86B.00.01.0013.030920180427
Op Code:........... 1.43.91F76955
ME Firmware Version:.. 04.00.04.294
SDR Version:.......... SDR Package 1.43
System Information:
Relevant part of the syscfg.INI file with previous firmware versions and with latest SysCfg:
Set Fan Profile=Acoustic ;Options: Performance=01: Acoustic=02
Fan PWM Offset=0 ;Options: 100=Max: 0=Min: 1=Step
Air Flow Limit=100 ;Options: 100=Max: 60=Min: 1=Step
Exit Air Temp=70 ;Options: 70=Max: 50=Min: 1=Step
Fan UCC=100 ;Options: 100=Max: 70=Min: 1=Step
This happens if I edit the Fan PWM Offset value in syscfg.INI and try to restore the file:
~$ sudo /usr/bin/syscfg/syscfg /r syscfg.INI /f /b
Restoring file syscfg.INI in progress...
"BootOrder::Hard Disk" is empty, skip this item
Failed to set "BIOS::Advanced::System Acoustic and Performance Configuration::Fan PWM Offset", "100" is an invalid value, skip this item.
So it seems the previous BIOS/firmware also had issues changing the Fan PWM Offset, that's probably why Intel tried to fix it in the latest version, but it just got worst.
Hello Szabolcsf,
We appreciate the additional information, we are going to check on your issue and will get back to you.
Sergio S.
SF_
Hi Sergio S.,
thanks! Is there perhaps an ETA? If you need anything else to reproduce the problem, just let me know.
Hello Szabolcs F,
Please refer to syscfg user guide at
Page 52 shows the PWM offset entry:
Fan PWM Offset=0 ;Options: 100=Max: 0=Min: 0=Step
Within the [BIOS::System Acoustic and Performance Configuration] section.
Additionally, please provide us with a copy of .ini file.
Sergio S.
SF_
I'm familiar with the user guide. The problem is either Syscfg or the BIOS/firmware has a bug that is preventing us from changing the Fan PWM Offset with Syscfg.
This is the full output of sudo /usr/bin/syscfg/syscfg /s /f /b : https://pastebin.com/6wtdc72a [INI file] ; Warning!!! Warning!!! Warning!!! ; --------------------------------- ; This - Pastebin.com
Notice that it doesn't have anything about the Fan PWM Offset. That's why Syscfg doesn't recognize that variable when trying to set. Read back my previous messages and see that I've been using the proper syntax.
So my question still stands: is there an ETA on a BIOS/firwmare/Syscfg fix?
Hello Szabolcs F,
We appreciate the additional information, we are going to provide the .ini log to our upper-level support so the can further assist you.
As soon as we get an update we will contact you back.
Sergio S.
Hello Szabolcs F,
First, we would like to apologize for the delay in our response.
For Fan PWM Offset changing please use dedicated command >syscfg -fan
See more details on page 44 of Syscfg User Guide https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/Intel_Syscfg_UserGuide_V1.02.pdf
Saving and/or restoring PWM offset settings to or from the .ini file is a limitation that is going to be fixed on a future version of the SYSCFG Utility.
Please do not hesitate to contact us again if you need further assistance.
Sergio S.
Hello Szabolcs F,
I am following your question and we would like to know if you need further assistance.
Sergio S.
SF_
thank you, it worked.
Hello Szabolcs F,
We are glad to hear that you were able to resolve your problem. Feel free to contact us back in case you need more assistance.
Sergio S.
