Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
S3420GPLX won't POST
Hi
I have a S3420GPLX motherboard that had been working fine for several months. I had previously purchased and installed the RMM3 module but never got around to setting it up. The other day I decided to set it up and booted into the BIOS to change the IP address of the RMM3 from Static to DHCP. I then saved and rebooted the computer. That's when my problems started.
The computer lights, fans and HDDs all started up but I got no display (LCD) and no lights on my keyboard or optical mouse.
I tried a full cold boot and even a new monitor(LCD), keyboard and mouse. Same result all dead.
I removed the RMM3 module and the only other add-in card - a dual port ethernet adapter.
I tried another power supply.
I removed the memory and got the 3 beeps.
When powering off the computer I get the 1-5-4-2 beep sequence.
CPU is Xeon X3450
Memory is Kingston KVR1066D3Q8R7S/8G
The POST Code Diagnostic LEDs show on-on-on-off on-on-off-off
which according to the manual is either:
0xEAh Flash Update; or
0xEEh Calling Int 19.
It looks like to me like the video and USB ports are not getting any power / signal.
I tried putting the BIOS in recovery mode and the LEDs showed off-off-on-on off-on-off-off
which is meant to be 0x34h Loading crisis recovery capsule.
Without a working video, keyboard or mouse I am pretty stumped.
DSilv11
Valued Contributor III
Makes it tought when the symptoms don't really make any sense. Setting an RMM3 to DHCP should have zero impact on the systems ability to boot.
First guess:
CMOS corrupted. Try clearing CMOS http://download.intel.com/support/motherboards/server/s3420gp/sb/sr1695gprx_tps_r1_5.pdf http://download.intel.com/support/motherboards/server/s3420gp/sb/sr1695gprx_tps_r1_5.pdf page 58
On BIOS recovery,
A few hints which are well buried in the documentation.
1) You need a DOS bootable USB keyfob. ( the system will boot to EFI , but for some reason it looks for a bootable partition)
2) You need to extract the code package to the root directory of the key fob. http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/20220/eng/S3420GPLXLC_EFI_BIOS49_BMC124_FRUSDR20.zip&lang=eng&Dwnldid=20220&DownloadType=Firmware&OSFullname=OS+Independent http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/20220/eng/S3420GPLXLC_EFI_BIOS49_BMC124_FRUSDR20.zip&lang=eng&Dwnldid=20220&DownloadType=Firmware&OSFullname=OS+Independent
These files are required to be in the root:
  • fvmain.fv
  • R0049REC.CAP
  • IFlashx64.efi
  • and a startup.nsh (which needs to be edited to just contain the line: iFlashx64 R0049REC.CAP /u )
3) Set the recovery jumper
4) Power -up and take a break. It takes a LOOOOOOONG time to complete. ( give it 10 minutes or more)
DSilv11
First guess:
On BIOS recovery,
  • fvmain.fv
  • R0049REC.CAP
  • IFlashx64.efi
Mate you are a genius!
I had tried to recover the BIOS but was unsuccessful.
Your steps were the answer and worked perfectly.
Thanks again.
