We have a S5000PAL board and we are getting red light on the front of the server. I looked at SEL (using ipmitool)
BIOS: Version: S5000.86B.12.00.0098.062320091136
110c | 08/06/2010 | 23:48:53 | Voltage BB +1.1V Vtt | Upper Non-critical going high | Reading 1.19 > Threshold 1.18 Volts
1120 | 08/06/2010 | 23:48:54 | Voltage BB +1.1V Vtt | Upper Non-critical going high | Reading 1.10 > Threshold 1.18 Volts
1134 | 08/08/2010 | 18:12:23 | Voltage BB +1.1V Vtt | Upper Non-critical going high | Reading 1.39 > Threshold 1.18 Volts
1148 | 08/08/2010 | 18:12:23 | Voltage BB +1.1V Vtt | Upper Critical going high | Reading 1.39 > Threshold 1.21 Volts
115c | 08/08/2010 | 18:12:24 | Voltage BB +1.1V Vtt | Upper Non-critical going high | Reading 1.10 > Threshold 1.18 Volts
1170 | 08/08/2010 | 18:12:24 | Voltage BB +1.1V Vtt | Upper Critical going high | Reading 1.10 > Threshold 1.21 Volts
1184 | 09/04/2010 | 10:18:29 | Voltage BB +1.1V Vtt | Upper Non-critical going high | Reading 1.39 > Threshold 1.18 Volts
1198 | 09/04/2010 | 10:18:29 | Voltage BB +1.1V Vtt | Upper Critical going high | Reading 1.39 > Threshold 1.21 Volts
11ac | 09/04/2010 | 10:18:30 | Voltage BB +1.1V Vtt | Upper Non-critical going high | Reading 1.10 > Threshold 1.18 Volts
11c0 | 09/04/2010 | 10:18:30 | Voltage BB +1.1V Vtt | Upper Critical going high | Reading 1.10 > Threshold 1.21 Volts
How should I interpret these lines? and what is Voltage BB +1.1V Vtt anyway?
SDR records:
ipmitool sdr elist
BB +1.1V Vtt | 10h | ok | 7.1 | 1.10 Volts
BB +1.5V AUX | 12h | ok | 7.1 | 1.47 Volts
BB +1.5V | 13h | ok | 7.1 | 1.48 Volts
BB +1.8V | 14h | ok | 7.1 | 1.80 Volts
BB +3.3V | 15h | ok | 7.1 | 3.30 Volts
BB +3.3V STB | 16h | ok | 7.1 | 3.35 Volts
BB +1.5V ESB | 17h | ok | 7.1 | 1.51 Volts
BB +5V | 18h | ok | 7.1 | 5.02 Volts
BB +12V AUX | 1Ah | ok | 7.1 | 11.90 Volts
BB +0.9V | 1Bh | ok | 7.1 | 0.91 Volts
Serverboard Temp | 30h | ok | 7.1 | 32 degrees C
Ctrl Panel Temp | 32h | ok | 12.1 | 23 degrees C
Fan 1A | 50h | ok | 29.1 | 9918 RPM
Fan 2A | 51h | ok | 29.2 | 9106 RPM
Fan 3A | 52h | ok | 29.1 | 10092 RPM
Fan 4A | 53h | ok | 29.2 | 10208 RPM
Fan 5A | 54h | ok | 29.1 | 9048 RPM
Fan 1B | 56h | ok | 29.1 | 14060 RPM
Fan 2B | 57h | ok | 29.2 | 14134 RPM
Fan 3B | 58h | ok | 29.1 | 14060 RPM
Fan 4B | 59h | ok | 29.2 | 14282 RPM
Fan 5B | 5Ah | ok | 29.2 | 13764 RPM
PS1 AC Current | 78h | ok | 10.1 | 0.62 Amps
PS2 AC Current | 79h | ok | 10.2 | 0.62 Amps
PS1 +12V Current | 7Ah | ok | 10.1 | 9.50 Amps
PS2 +12V Current | 7Bh | ok | 10.2 | 10 Amps
PS1 +12V Power | 7Ch | ok | 10.1 | 112 Watts
PS2 +12V Power | 7Dh | ok | 10.2 | 120 Watts
That's the onboard CMOS battery. They're not covered by warranty, but they're pretty easy to find and cheap to replace.
