I have Intel S5500BC server board with 2 Xeon E5504 processor and want upgrade memory.
Is the Kingston KVR1333D3D8R9S/4GI 4GB 1333MHz DDR3 ECC Reg CL9 DIMM DR x8 w/TS Intel compatible with this configuration?
On information of Kingston:
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=54353&root=us&LinkBack=http://www.kingston.com&Capacity=4+GB&Speed=Speed&DIMM=DIMM&ErrCheck=ErrCheck&Rank=Rank&Chip=Chip&Submit=Refine+Search http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=54353&root=us&LinkBack=http://www.kingston.com&Capacity=4+GB&Speed=Speed&DIMM=DIMM&ErrCheck=ErrCheck&Rank=Rank&Chip=Chip&Submit=Refine+Search
is compatible, but this memory module is absent in Intel Server Configuration Tool validated memory list.
Not on Intel's tested list doesn't mean it won't work. It's on Kingstons' list means it passed Kingston's test, so most likely it will work. However if you use it and encounter any issues you'll get very limited support from Intel.
