Server Products
4873 Discussions
S5500BC with another chassis
MAbuc
Hello to ALL
I currently have 2 server boards S5520HC and S5500BC both running inside SC5650WS and SC5650DP respectively, due to increased storage requirement i was wondering if i can switch them to the newer intel chassis such as the P4308, if yes which one due recommend ?
Kindest Regards
Edward_Z_Intel
Unfortunately, none of the Intel® Server Chassis P4000 family is tested or validated on S5520HC or S5500BC. For a list of tested chassis, see the following pages:
S5520HC: http://www.intel.com/support/motherboards/server/sb/CS-030487.htm Tested chassis list
S5500BC: http://www.intel.com/support/motherboards/server/s5500bc/sb/CS-030486.htm Tested chassis list
