I'm having issues with the above configuration - it can't see the battery.
The S5520HC has the latest package through efi (63;61;33;112).
Initially the raid rom did not show. I powered off the system, unplugged the battery, powered on - all good.
I then tried the battery again. The rom loads but does not see the battery. I left it for an hour so that I can rule out a flat battery.
Still no good.
I've tried another battery & it's still not seen. Both batteries had a flashing red led on the back.
I've even flashed the SROMBSASMR with firmware 11.0.1-0051.
I've uesd AXXRSBBU3 batteries in the past with no issue. These are now discontinued...
I'm connecting the battery to the raid with the supplied 20pin cable. Pin 1 was marked with texta and I can see I haven't plugged anything incorrectly.
Any ideas?
Rob
I'm afraid only AXXRSBBU3 is supported on SROMBSASMR. AXXRSBBU8 is for different RAID controllers.
