I wish to upgrade the graphics capeability but I am unsure which type of graphics cards I can use, anything from 128mb upwards which type, which slot???????????????????????????
Thanks Pete
- Tags:
- Intel® Xeon®
See http://www.intel.com/support/motherboards/server/se7520bd2/sb/cs-013538.htm http://www.intel.com/support/motherboards/server/se7520bd2/sb/cs-013538.htm for the list of supported graphics cards
Hi Dan_O
Many thanks for the response I remember seeing that pdf file unless I'm looking through glossey glasses I could not see anything that refers to compatible graphics cards or am I missing something?????
Any more pointers would be grateful!
One last thing curiosity more than anything would it be a problem turning a server machine into a pc change the OS to vista/win 7/ ubuntu etc????
Thanks Pete
It's entirely possible no graphics cards were tested. They often take lower priority on a server board, as opposed to a desktop board.
You can run a server as a single client, like you say. But you'll probably run into the same compatibility limitations - no support for desktop OSes, common desktop peripherals, etc.
