Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4615 Discussions
SS4200-E external usb disk - cannot write
We have a SS4200-E machine. I connect an external 1,5TB disk to it (Seagate freeagent) and the ss4200 recognizes it and gives it a folder name (USB_Seagate_FreeAgent). Problem is whatever I try, I cannot write to the external disk, ony read from it, even if a set it (from the admin page) as Not Secured.
I have tried
* setting the folder as Not Secured, still I cannot write to it (it still shows the lock icon even if I set it as Not secured)
* setting it as Secured write and/or Secured read/write with full read/write permissions for any user, still all users are set to Read only. Even the admin.
* creating a new User and giving it write access- still cannot write (i select Read/Write for the user, click Apply but still it says it is set only to "Read")
Any suggestions? What am I doing wrong?
Edward_Z_Intel
Are you using NTFS on your USB hard drive? You'll need to format it to FAT32 to make it writable... See http://www.intel.com/support/motherboards/server/ss4200-e/sb/CS-028598.htm.
