Problem with Intel Server (Canoe Pass) S2600CP4 board.A record appears in the logs: "Warning event: Temperature sensor 87 reports the sensor is in a high, but non-critical, and going higher state. Sensor reading: Unspecified. Threshold value: Unspecified." After this event, the server reboots after a few hours. What to do? what to replace?
yes, I'll try to figure it out
Thanks for the help! So far I can not do anything with the server, as it is in work. On Saturday or Sunday I will do all the options and be sure to let you know.
When installing sysinfo encountered problems:
1. Clause 2.1.2. I can not run sysinfo.efi.
2. If I use Windows, then under clause 2.2.1 I cannot find the file memrwdinstall.bat in the downloaded archive
I can provide a screenshot of the selview utility
Good afternoon, started from windows. The magazine that was formed - sent. There is another file, but it is empty, there is no data, only the header. No more files have been generated. Launched the sysinfo utility.
Thank! I will wait!
Attention! The picture and text about a successful rebuild is incorrect! The server in the logs writes after rebooting ALWAYS a successful rebuild raid!
I have S2600CP4 board
Are the indicated links correct for the specified board?
and most importantly: won't the raid currupt?
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
