Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4544 Discussions
Server rail lengths (AXXPRAIL and AXXVPSRAIL)
GRIFFCOMM
Hi
We ordered the AXXPRAIL, its length (approximately) when in the RACK and closed it about 830mm from the front rail to the back of the rail (out the back of the rack).
I need to know the length of the RAIL kit AXXVPSRAIL when closed from the front of the rack to the back of the rail when its closed (we have a distance issue in the server rack to the wall).
We already ordered the AXXPRAIL so will need to be used when the rack is moved as we needed the cable managment kit, however i have to mount the server so need to know the length of the other rail that fits this server to at least get it in the rack without the cable management for now..
Many Thanks
GRIFFCOMM
Is no one able to check this?
Many Thanks
