I would like to perform an unattended upgrade of the firmware of a S2600KP node as part of a Windows 2012 R2 installation. I have an ISO which deploys the OS and then automatically executes a bunch of scripts to upgrade the system and firmware.
The problem I encounter is that the OFU flashupdt tool requires user interaction. The silent upgrade is impossible due an interactive menu. Has anyone been able to automate this?
Secondly the tool says "Exiting without performing any updates" but then goes on to update the BMC/BIOS etc. This is kind of misleading.
Could Intel improve the usability of their tools so that such scenarios can be addressed with ease? Is there an Intel email address to which one can send feedback?
Sample Output:
C:\Install\OFU_V13_1_Build9_AllOS\Win_x86>flashupdt.exe -u \Install\S2600KP_SFUP_BIOS01010009_ME030007168_BMC0135r9065_FRUSDR109_updated\flashupdt.cfg
One Boot Flash Update Utility Version 13.1 Build 9
Copyright (c) 2015 Intel Corporation
Update file Configuration: XXX S2600KP,1.0
Processing capsule file - \Install\S2600KP_SFUP_BIOS01010009_ME030007168_BMC0135r9065_FRUSDR109_updated\R0009.cap
Processing capsule file - \Install\S2600KP_SFUP_BIOS01010009_ME030007168_BMC0135r9065_FRUSDR109_updated\R0009_ME.cap
Update file Configuration: Revision S2600KP_109
FRU & SDR Update Package for Intel(R) Server Board S2600KPx (S2600KP_109)
Copyright (c) 2014 Intel Corporation
Intel(R) Server Board S2600KP detected
Select the function you want to perform:
1 Update only the SDR
2 Update only the FRU
3 Update both the SDR and the FRU
4 Modify the Asset Tag Only
5 Exit FRU/SDR update
Selection out of range, please select from 1 to 5.
5
Processing BMC FW Controller
Querying USB Interface ...
Using USB Interface...
Sending update options to firmware: Done.
Transferring BMC Firmware Image:
100% Done.
BMC Firmware Update Status:
100% Done.
BMC Firmware Update Successful
This may take upto 50 seconds to exit. Please wait...
BIOS Update In Progress: 100%
Primary Update completed, Backup BIOS update will be completed in next boot.
BIOS has been updated successfully.
Please restart the server for the update to take effect.
ME Update In Progress: 100%
The ME Firmware has been updated successfully.
Successfully Completed
Please contact our support group directly for further assistance on your inquiry:
http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
With inputs from some colleagues, I found that the behavior of flashupdt.exe can be modified by editing master.cfg which is called by flashupdt.cfg
