I downloaded the various methods of updating the bios but in the UEFI zip file, startup.nsh is missing, in the method OFU, there isn't the file *.cfg.
How do I upgrade? I also have the Intel Case SC5299DP.
Both files seem to be in the most http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/20303/eng/S3420GPLX LC_BIOS49_BMC124_FRUSDR20.zip&lang=eng&Dwnldid=20303&DownloadType=Firmware&OSFullname=OS+Independent current package
I just wanted to let you know, that while your question may get answered here in the Server Room Forum, you may get a quicker answer in the specific /community/tech/servers Server Tech Support Community.
- Cory
Which file did you download? Maybe it's not completely download. Try to download again and make the file matches with the listed size.
I checked and the problem is that in search mode select the system Windows Server 2008 and did not see the BIOS update.
![](/skins/images/71A9511A625CE5D5D45FB59952A4AA71/responsive_peak/images/icon_anonymous_message.png)
