I just wanted to ask if I can upgrade from SRCSATAWB to RS3UC080 without losing an existing RAID5?
So that I can just change the controller and everything works like before in the RaidWebConsole2?
Something else I need to know when I want to do that?
Thanks!
The RAID controller should automatically see the existing configuration, and give you an option to import the configuration from the drives.
