I have a Intel S5520HCT motherboard with duel Xeon L5630 running Windows 2008 R2. I am using Kingston DDR3 1066 Parity Registered ECC memory (KVR1066D3D8R7S/4G). On the Kingston website it says this RAM is certified for my motherboard and CPUs.
However, when I install 48GB of RAM (all channels filled) the performance is so poor the system is almost unusable and the CPU utilization is near 100% when I run even the most simple program. When I remove 2 RAM modules from a channel on each CPU/memory-controller (now 32GB total) the performance vastly improves to an acceptable level.
I thought this may be a problem with the Registered memory, so I took non-registered ECC 4GB RAM (KVR1333D3E9SK2/8G) from two other machines and installed them. But shockingly I saw the same behavior. So it is obviously something with the motherboard.
Has anyone experienced this behavior before, and if so how did you solve it?
Kevin
Thanks Edward. This worked!
