SSD 가 fail 되어 3번 slot의 SSD 를 기존 제품이 없어서 용량이 틀린 제품을 장착 했습니다.
RAID Web console2 에서 확인 한바 rebuild 후에 앞에 노란색 자물쇠 모양이 생기는데요 어떤 의미인지 알수 없어 문의 남깁니다.
Hello Randy_Ahn,
I understand that a drive was replaced since one of them failed.
Based on the icon it looks like this is related to Locked or Unlocked SED (self-encrypting drives).
- Are you having any issues with the RAID setup?
- The failed drive should be replaced with an identical drive of the same capacity or larger.
Adrian M.
Hello Randy_Ahn,
Let me know if you need more assistance.
Please provide the model of your server board as well and if you are having any RAID issues let us know to further assist you.
Adrian M.
Hello Randy_Ahn,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
![](/skins/images/44D6FBC13D1AFC21DF3F0C7813903D74/responsive_peak/images/icon_anonymous_message.png)
