Hi Team,
we are working on breechnut city with GNR, Issue entering into BIOS.
for Display used MiniDP to VGA (comes along with Server) and a VGA Cable with VGA monitor.
1. we couldn't enter into BIOS while Pressing F2. LED on Wired Keyboard is not seen (not sure if Keyboard is getting detcted).
2. Tried using, Type C Serial Port, couldn't see any COM port in other devices to install required drivers.
3. RESET button on pront panel is downside pushed.
Kindly help on figuring out what could be the issue.
We connected Ethernet cable into management port and could get DHCP address allocated and load the Webpage, but default user and password are not known.
Thank you,
Rohith
Update:
we are able to enter BIOS using USB-C serial Port. but still can't set BMC UI user and password.
can some share default user and password to login into OpenBMC.
we tried with user 'root' & password as '0penBmc'.
Rohith
Hello Rohith,
Greetings for the day!
Thank you for contacting Intel regarding the Intel Beechnut City Platform BMC issue.
Since the Intel Beechnut City Platform-related queries under the Intel Software Development Platform (Intel SDP) Support Center. We recommend you post your query on the Intel Software Development Platform (Intel SDP).
Please find the below article for How to Access the Intel Software Development Platform (Intel SDP) Support Center.
https://www.intel.com/content/www/us/en/support/articles/000095889/programs.html
Thank you for your support and understanding!
Vikas
Hi Vikas,
Thank you for the suggestion. we were able to login set login credentials for BMC by going over BIOS EDKII options.
below article also helped.
How to Reset the BMC Password and Username for an Intel® Server...
I have registered for SDP, going forward I will post my questions there.
Rohith
Hello Rohith,
Thank you for your response.
Since we referred you to the Intel Software Development Platform (Intel SDP) Support Center we are closing this request.
Please don't hesitate to ask any further questions in the future.
Feel free to start a new conversation, as this thread will no longer be monitored.
Vikas
