Hi
Can anyone can help me on this issue can i run my new xeon W35675 Bloomfield processor on a windows 7 32bit operating system?
Or i must use 64bit.
No problem on the CPU side, but you'd better check if your server board/system supports Windows 7.
Thank you for your respond!
my system board is
ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboardmy memory
CORSAIR DOMINATOR GT 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model CMT4GX3M2A2000C8What do you think?
I did a quick check on ASUS site and didn't found any Xeon CPUs on its CPU support list:
http://www.asus.com/product.aspx?P_ID=wurRaDZ8lo4Ckukj http://www.asus.com/product.aspx?P_ID=wurRaDZ8lo4Ckukj
So you may want to double check with ASUS if you can use this CPU on your board. If the answer is yes then you'll be able to run both 32-bit and 64-bit Windows 7.
