Buongiorno a tutti,
ho appena acquistato una scheda S320SHV con 3 HDD configurati in RAID 5 con Intel Matrix Storage, ho scaricato i driver aggiornati dal sito, caricati su un floppy, partito con opzione F6 ma dopo aver caricato i driver con successo l'installazione si ferma al momento di rilevare i dischi e mi dice che non ci sono controller installati. Ho provato ad installare windows server 2008 64bit e funziona correttamente. Penso di avere dei driver sbalgiati o di selezionare quello sbagliato dall'elenco. Mi potete aiutare? Grazie.
Hi there,
Unfortunately, i dont speak Italian.
The reason that the Windows 2008 worked, is due to the fact that there is the Intel Matrix F6 drivers already embedded in the Windows.
So far, i tried nearly all OS on this board and it worked fine. I installed Windows 2003 (32 bit and 64 bit) and Windows XP (32 bit and 64 bit) in RAID Mode without any problem.
Steps done:
Bios: Configure SATA as RAID and Intel Matrix (not LSI)
Ctrl + I - to create my raid.
Using the internal floppy disk drive, i loaded a floppy disk with the F6 drivers in it.
Website:
http://downloadcenter.intel.com/T8Clearance.aspxsType=&agr=Y&ProductID=2869&DwnldID=16098&url=/16098... http://downloadcenter.intel.com/T8Clearance.aspxsType=&agr=Y&ProductID=2869&DwnldID=16098&url=/16098...
Insert my OS installation disk and press F6, followed by S to specify the location of the drive.
Continue the OS installation.
Alternative Steps:
Using Nlite to slipstream the F6 drivers thus creating a new OS CD with the drivers already embedded.
That's all. It worked fine 100%.
Kind Regards,
Aryan.
Thanks for your help. I try it and it's ok. I made a mistake selecting type of controller during driver upload. Now i select type ICH9R and i see hdd. Thanks.
For more complete information about compiler optimizations, see our Optimization Notice.
