Hello, I have a problem with my i7-930 he is overheating
My gear
Asus Rampage III extreame
CPU i7-930 2.8GHz (stock no OC)
Corsair 1000W Silent Pro Gold
3X4 Corsair memory vengeage 2000MHz
Standard intel cooler
Tthermal artic grease MX4
Room temp about 20° C
Processor 45° C
Even outside the case on my desk the temperature starts at 45 ° C without load.
I googled and found several similar cases without a clear answer.
Can u help me ?
Well I won't call 45° C overheating.
humm, if u say that.
Now 44~46°C idle at bios no load at all withh my room temp at 20°C for me is hot, becouse when I start windos the computer restart and got CPU temp high, in the case my Tcase is 64.9.
Guys where re u
A little help here pls
The cause of the problem in my case was an electrical problem on the motherboard, since replaced the motherboard and the cooler for a H70 these are the results.
[URL=http://img832.imageshack.us/i/tempi7930.jpg/ http://img832.imageshack.us/i/tempi7930.jpg/][IMG]http://img832.imageshack.us/img832/8295/tempi7930.jpg http://img832.imageshack.us/img832/8295/tempi7930.jpg[/IMG][/URL]
[URL=http://img9.imageshack.us/i/tempi7930a.jpg/ http://img9.imageshack.us/i/tempi7930a.jpg/][IMG]http://img9.imageshack.us/img9/9213/tempi7930a.jpg http://img9.imageshack.us/img9/9213/tempi7930a.jpg[/IMG][/URL]
Room Temp at 19º~21ºC.
Thank you all for your help.
![](/skins/images/01F111D2651B8D490886918A505C4147/responsive_peak/images/icon_anonymous_message.png)
