Hi everybody,
I have the SR2500ALBRP server ( 1 CPU - 2 Ram modules ).
The machine was working without any problems until yesterday.
Suddenly i found the status led ( front panel ) blinking green - amber. I know this led blinks green or amber but not both.
I disconect the power and connected again ( both PSU ).
Status led green (Steady no blinking )
When i push power button status led blinks green, fans working at full speed, no boot beep, no video.
After 1 minute status led turns to amber and blinking. Fans continue to run at full speed, no video, no beep, no boot.
Push the power button again to turn off, the system going off and the status led blinking green - amber. again
After 15 minutes without any action from me the status led turns again to Steady green.
If i try to power on again the same cycle repeat.
I try memory change, nothing
I remove memory and nothing again. No beep, No Post.
Can anyone Help ?
Thanks in advance
Liakos
Due to discontinuance, the support that we offer is only through the website but as a general recommendation test the board without memory looking for beep codes. No beep codes will be an indicator that the board is defective. Clear the CMOS battery for 1 minute.
Thanks for your answer.
Aw i said in my post, i tried without RAM and i can't hear anything.
I tried clear CMOS and the result is the same.
CMOS battery was off so i replace it with a new one.
Also the diagnostic leds ( rear panel ) are all off.
Where is the board speaker? I can't find it. Maybe is disconected so i can't hear anything.
What else can i do to ensure that the board is defective?
Thanks again for your time
Ilias
