Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
ipmitool and dmidecode differences with servers with S2600WFT MB installed
Joecastle73
I have 2 identical S2600WFT servers. There are differences in ipmitool fru print output for Product  Part Number,Product Version and Product Serial Number  and dmidecode  output for Version and Serial number between the 2 servers. The chassis SN is used to track changes on the server.  How do I fix this
## IPMITOOL FRU PRINT differences
## ipmitool fru print 0
# Good server ( 040-15)
<--------------------- 040-15 -------------------------------->
Chassis Type : Rack Mount Chassis
Chassis Part Number : ..................
Chassis Serial : ..................
Chassis Extra : ...............................
Board Mfg Date : Wed Jul 29 22:10:00 2020
Board Mfg : Intel Corporation
Board Product : S2600WFT
Board Serial : BQWF02600555
Board Part Number : H48104-883
Product Manufacturer : Intel Corporation
Product Name : S2600WFT
Product Part Number : K72774-001
Product Version : LWF1208YR54000B
Product Serial : LUF903100047
Product Asset Tag : ....................
# Bad server ( 040-21)
<--------------------- 040-21 -------------------------------->
Board Mfg Date : Thu Jun 25 00:24:00 2020
Board Serial : BQWF02600287
Board Part Number : H48104-873
Product Part Number : ..........
Product Version : ....................
Product Serial : ............
## DMIDECODE differences
## dmidecode -t system
# Good server (040-15)
# dmidecode 3.0
Getting SMBIOS data from sysfs.
SMBIOS 2.8 present.
Handle 0x0038, DMI type 1, 27 bytes
System Information
Manufacturer: Intel Corporation
Product Name: S2600WFT
Version: LWF1208YR54000B
Serial Number: LUF903100047
UUID: 002609F7-AABA-EA11-906E-0017A4403562
Wake-up Type: Power Switch
SKU Number: SKU Number
Family: Family
Handle 0x0045, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
# Bad server (040-21) : version and Serial Number missing
# dmidecode 3.0
SMBIOS 2.8 present.
System Information
Version: ....................
Serial Number: ............
UUID: 80B069C7-9BB6-EA11-906E-0017A4403562
Family: Family
## audit of the BIOS and FW show both nodes are the same
##  Good node
 Server Firmware Intel R1208WF/S2600WF Audit Utility
RPM Version: 02.01.613.01
Script Version: 2.80.0
* INTEL BIOS AUDIT *
Current BIOS Version: SE5C620.86B.02.01.2013.C0T09.020120210920
Certified BIOS Version: SE5C620.86B.02.01.2013.C0T09.020120210920
Current BMC Version: 2.48.CE3E3BD2
Certified BMC Version: 2.48.CE3E3BD2
Current ME Version: 04.01.04.423
Certified ME Version: 04.01.04.423
Current SDR Version: 2.01
Certified SDR Version: 2.01
Log: /var/opt/teradata/teradata-server-firmware-S2600WF/LOGS
Server Function: SQLE
CPU Microarchitecture: SKX
Conflicting F/W Versions: 0
Conflicting BIOS Settings: 0
0 Mismatch(es) found between certified BIOS settings and current BIOS settings
# Bad node ( SMP040-15)
Log:
Paul_R_Intel
Hello Joecastle73,
Thank you for joining the community,
I understand that are missing some details on the ipmitool fru print output. Can you please run the following commands:
  • ipmitool raw 0x30 0xD0 0x$HSBP 0x$drive 0x1
  •  ipmitool raw 0x30 0xD0 0x$HSBP 0x$drive 0x3
 We have noticed that the BIOS version is currently System BIOS - 02.01.0013 we recommend you to update to the latest System BIOS - 02.01.0015 if the issue persists.
You can find the update here:
Important:
 If you try upgrading directly from an older BIOS version to a new version but do not meet firmware requirements, the upgrade may fail. Please upgrade to version System BIOS - R02.01.0014 first.
Please let us know the outcome.
Paul R.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
Paul_R_Intel
Hello Joecastle73,
 We would like to follow up on your thread, We would like to know if you need further assistance. In case you do, we would highly appreciate if you would let us know.
Paul R.
Paul_R_Intel
Hello Joecastle73,
 We would like to follow up on your thread, We would like to know if you need further assistance. In case we do not hear back from you we will proceed to mark the thread as closed in 2 business days.
Paul R.
