Server Products
4792 Discussions
missing SATA driver with Installing Windows 7 Pro on Intel Server Board S5500BC
JSO2
I have started installing Win 7Pro when it got to the point where it asked for a driver for storage device, I searched the Intel support site and found S5500 Based Server AHCI SATA Storage Driver for Windows, downloaded the
File name:
RST_9.6.4.1002_Win_drivers_and_utils.zip, unzipped it , choose "Intel® ICH10R SATA AHCI Controller" but I got a blank screen, why?
I checked the motherboard BIOS selected AHCI for MASS Storage Device then browse for driver again this time it picked ICH10R SATA AHCI Controller however it still won't install Windows 7. Anyone have this problem before ? I setting the machine up with one hard disk and one DVD ROM only. Where is the correct SATA driver for this motherboard?
JSO2
Forgot to say , hard disk was used on a RAID 5 setup with a adaptec controller, condition of the drive close to brand new..
Daniel_O_Intel
If you are using an adaptec RAID controller, you should be using an adaptec driver. The driver you downloaded is only if you are running the drive off the motherboard ports.
JSO2
not using Adaptec RAID controller anymore so SATA drive is connected to motherboard SATA 0 .
JSO2
Since the hard disk was used in a RAID setup previously should I reformat the hard disk ?
SWood11
you're using the correct drivers. try wiping the disk out and try again. it could be picking up leftover adaptec metadata on the disk.
