I have a problem in my S2600CP2J board, firstly I installed a GPU (MSI GTX 760 OC) on the x8 blue PCIe slot the second one after the x16 slot, when monitor connected with the new GPU, the screen not show anything during boot (no POST or windows boots screen and no signal to monitor) and the monitor turns on after windows enter to the login page.
After reviewing the BMC log I see some errors related with PCIe, the picture is attached below
Here are our recommendations for the issue:
- Please review the following link that might apply for your issue:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000008008.html PCI Express* Link Bandwidth Changed Error Message May Be Logged in...
- Make sure you have the latest firmware update for the board.
- Test a different PCIe device to confirm the slot is working fine.
- Issue could be related to compatibility so we suggest using validated hardware from:
https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE=1\ https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE…
