Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4873 Discussions
"The virtual disk has not been initialized. Running a consistency check may result in inconsistent messages in the log. Are you sure youwant to contimue?"
DCraf
We are running a Windows Server 2012 R2 standard with Intel Embedded Server RAID Technology II storage controllers. Disk Management says that the drives are healthy but are getting some disk errors in event viewer. When we run the Intel RAID Web Console 2 utility consistency check we get the follow popup window "The virtual disk has not been initialized. Running a consistency check may result in inconsistent messages in the log. Are you sure you want to continue?"
Why would that be if disk manger says the drives are healthy?
Please contact our support group directly in order to review the RAID logs and narrow the issue based on that report:
http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
