Hi everyone... I have a problem, I build a serverboard s5520sc in the sc5299ws chassis, and now my fan speed are very very high, bios and firmware already update, somebody have idea for me?
Thanks...
I would recommend following the recommendations listed in our article http://www.intel.com/support/motherboards/server/sb/CS-022809.htm System Fan Runs Too Fast or Too Loud. I noticed you mentioned you already updated the BIOS. Do you recall which selection you chose for the FRUSDR?
Additionally, the chassis you are using uses 3 system fans, aside from the processor fans. Make sure the fans are connected on SysFan1, SysFan3, and SysFan5.
If the issue remains, please run our https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=19657 Intel System Information Retrieval Utility to review the information of your logs.
