Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4659 Discussions
system interrupt controller - server board SE7520AF2
Mmarr4
Hi
Had to rebuild server, and having difficulties with this device, in device manager
system interrupt controller - has an exclamation
Can someone guide me to the exact driver download location for windows 2003 server.
I have tried downloading various drivers from the intel site, none of which helped.
thanks
Daniel_O_Intel
That is the chipset driver. Did you already install
http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20019 http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20019 ?
If so, you may need to power off the system, pull the AC for twenty seconds, then boot into the BIOS and reset to factory defaults.
Daniel_O_Intel
Mmarr4
Installing those drivers in the previous reply worked!
i'm sure I installed the system board drivers previously, maybe they were not the correct ones.
thanks for your help
