Software Archive
Read-only legacy content
17060 Discussions
1024x640 resolution on GM965 Express, Dell XPS 1330 notebook
domas
Hello there,
just bought dell xps 1330 laptop. The only widescreen resolution is 1280x800, it is too small for me, im getting eyestrain after a hour by working with it.
More comfortable should be 1024x640 resolution, is it possible to modify GM965 Express driver to apply it? I acctualy dont know does my monitor support it.. I use Windows XP Professional.
MonInfo log:
Monitor
Windows description......... Plug and Play Monitor
Manufacturer................ LPL
Plug and Play ID............ LPL0000
Serial number............... n/a
EDID data source............ I2C bus (real-time)
Manufacture date............ 2007
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 290 x 180 mm (~14")
Power management............ n/a
Color characteristics
Display gamma............... 2.20
Red chromaticity............ Rx 0.592 - Ry 0.345
Green chromaticity.......... Gx 0.333 - Gy 0.541
Blue chromaticity........... Bx 0.160 - By 0.149
White point (default)....... Wx 0.313 - Wy 0.329
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... n/a
Vertical scan range......... n/a
Video bandwidth............. n/a
Extension blocks............ n/a
Timing recommendation #1.... 1280x800 at 60Hz
Modeline................ "1280x800" 71.500 1280 1328 1360 1440 800 803 809 827 -hsync -vsync
Standard timings supported
n/a
Raw EDID base
00: 00 FF FF FF FF FF FF 00 32 0C 00 00 00 00 00 00
10: 00 11 01 03 80 1D 12 78 0A 96 11 97 58 55 8A 29
20: 26 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 EE 1B 00 A0 50 20 1B 30 30 20
40: 36 00 1E B3 10 00 00 18 00 00 00 00 00 00 00 00
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 55
60: 4E 38 36 34 06 31 33 33 57 58 31 0A 00 00 00 FE
70: 00 1F 36 42 4C 6B 8A B2 FF 01 01 0A 20 20 00 8A
Display adapter
Adapter description......... Mobile Intel 965 Express Chipset Family
Adapter device ID........... 0x2A028086
Display settings............ 1280x800, 32bpp
User/computer information
Registered user name........ dom
Registered organization..... n/a
Network user name........... dom
Network computer name....... DELL
Windows version ............ Windows XP
Windows build .............. 5.01.2600 Service Pack 3
Installation date .......... 5/19/2008 12:00:00 PM
Thanks!
7oby
New Contributor II
Hello domas,
your 13,3" TFT display has a native resolution of 1280 x 800 pixel. There are indeed ways of displaying different resolutions on this display, but the display has to interpolate pixels in this case. The result is a blurry display with even more eyestrain for most people. That's why it's not enabled by default.
The solution proposed by Microsoft is that you increase the DPI (dots per inch) telling the number of pixels actually present per inch. If you do your maths correct (sentence of Pythagoras) you will discover that your display has 113,5 dpi. Try telling Windows 120dpi (the default is 96) according to this guide:
http://www.lawfirmsoftware.com/support/change_dpi_settings_xp.htm
The result will be enlarged fonts. The resolution still used is 1280 x 800 and results in smoother font edges and more fine grained drawings etc. Internet Explorer adapts to that setting, but I don't know whether Firefox does. You might want to enlarge fonts in the one or other application manually.
There exist some cases where certain icons or symbols do not get enlarged, but please first try this one. In general it's the better solution.
