Software Archive
Read-only legacy content
17060 Discussions
1D Real FFT Issue on MIC
Aljosa_V_
I am compiling code included below into a native MIC application.  The executable is deployed via Windows COI API.  If I put a break point after the DftiComputeForward() call and display memory contents of x & y, I see that the input data has been clobbered by the call and y is unchanged (or has been overwritten with the identical values of 0).  I looked over the documentation and would expect MKL to use y as an output instead of performing FFT in place since DFTI_REAL has been specified as the forward domain in the DftiCreateDescriptor() call.
Is this a BUG or am I using the MKL API wrong.
Host OS: Windows 7
MKL version: 11.1.2.176 (w_mkl_11.1.2.176.exe)
Cheers,
Al
    float x[512];
    float y[512];
    MKL_LONG status;
    for(int_t i=0; i<64; i++) {
        x = (float)i;
        y = 0;
    DFTI_DESCRIPTOR_HANDLE dscHnd;
    status = DftiCreateDescriptor(&dscHnd, DFTI_SINGLE, DFTI_REAL, 1, 8);
    if(status != 0) {
        goto _err;
    status = DftiCommitDescriptor(dscHnd);
    if(status != 0) {
        goto _err;
    status = DftiComputeForward(dscHnd, (float *)x, (float *)y);
    if(status != 0) {
        goto _err;
    DftiFreeDescriptor(&dscHnd);
Evgueni_P_Intel
Dear Aljosa,
By default, MKL FFTs are in-place.
To do an out-of-place transform, please add the following line before DftiCommitDescriptor.
DftiSetValue(DFTI_PLACEMENT, DFTI_NOT_IN_PLACE);
I also recommend reading the section about the DFTI_PACKED_FORMAT value in the MKL Reference Manual.
Thank you.
Evgueni.
Aljosa_V_
Thanks Evgueni,
That explains it.  I expected the MKL to automatically assume I am interested in a not-in-place case since I used function call that provides both x & y as opposed to the one that only supplies x_inout.
Al
