Software Archive
Read-only legacy content
17061 Discussions
2 separate apps in one installation
HexLord
My app puts two icons on the desktop after installation.
The two icons launch two separate apps.
It will be like having two separate apps bundled into one installation.
I hope this is OK.
Just wanted to be sure about this.
Shaleen
Wezley_S_
I'm sure this would be fine, but the judges will more than likely ONLY use the application that they're judging.
samontab
Valued Contributor II
As long as you supply the installer in both entries, I guess you are alright. A bit confusing though.
HexLord
The plan is to provide a single installer that installs both.
@Wezley, does that mean only one of my apps will be judged? They are both included in the idea I submitted for this challenge.
Shaleen
samontab
If you have two ideas/projects in the web interface, you need to put the installer on each.
If you only have one idea/project that needs two apps, that should be fine.
HexLord
yup..that was my question..thanks:)
