Software Archive
Read-only legacy content
17061 Diskussionen
82801JI (ICH10) Raid (aka matrix storage manager)
lifeless
Einsteiger
1.272Aufrufe
Hi all, I've been looking around on the intel site for a few hours now, trying to find a technical specification for the matrix storage manager metadata fields in the latest ICH10R controllers.
I own one of these, and run Linux. Previous versions seem to have had their signature and metadata located at 1K(two sectors) back from the end of the disk; mine has metadata, apparently correctly formatted such that the current dmraid code understand it [my volumes mount - thats a good start], but set back 2115 sectors from the end of the disk.
So I'm writing an update to the isw ataraid driver in dmraid, and while I have figured out enough by simple inspection of whats on the disk, to get it going - it would be great to have an actual specification so that I can make it as robust and correct for other people as possible.
This bug report https://bugs.edge.launchpad.net/ubuntu/+source/dmraid/+bug/372170 contains more detailed data if anyone cares to look :). But my primary interest is to find some specs on the hardware I have :).
Thanks in advance,
Rob
4 Antworten
Gina_B_Intel
Mitarbeiter
1.272Aufrufe
Hello, this is a hardware question that I will submit for you at http://supportmail.intel.com/scripts-emf/welcome.aspx. You should receive a response from the hardware team within 48 hours.
-Gina
lifeless
Einsteiger
1.272Aufrufe
Thanks!
-Rob
Intel_Software_Netw1
1.272Aufrufe
For tech specs, you might also check http://ark.intel.com/.
The team in charge of the hardware designer corner of intel.com can be reached through: http://developer.intel.com/design/sitehelp/
For HW design support, you would need to work through eitheryour company's Intel rep ora Field Application Engineer at an Intel Authorized Distributor in your area.
Lexi S.
Intel Software Network Support
http://www.intel.com/software
email: ISN.support@intel.com
Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
*Other names and brands may be claimed as the property of others.
qiuting200
Einsteiger
1.272Aufrufe
Quoting - lifeless
Thanks in advance,
Rob
I was trying to find the raid metadata specification too,but I can't find it
Can you send me a copy ,3q
email: qiuting200@gmail.com
Antworten
