So I came into work this morning and my resolutions had gone all wonky. I am using a Dell Latitude 520 with a 945 chipset.
Monitor 1: Hannsg JC199D (digital)
Monitor 2: Hannsg JC199D (analog)
connected through a docking station.
Monitor 1 works fine, it'll still go up to 1280x1024 fine, but Monitor 2 is locked in at 800x600 or 1024x768, no more choices - and can't change it through vista or intel software.
I have swapped connections, I have swapped docking stations, I've swapped cables, I've uninstalled drivers. Both monitors register as the models above in device manager, but when looking at the info for intel it says pnp. It's almost as if it thinks the analog monitor is the laptop monitor (it's top res is 1024x768)
here's the information from intel
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 03/04/2009
Report Time[hr:mm:ss]: 10:05:43
Driver Version: 7.14.10.1504
Operating System: Windows Vista Business* , Service Pack 1 (6.0.6001)
Default Language: English
DirectX* Version: 10.0
Physical Memory: 2037 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 256 MB
Graphics Memory in Use: 90 MB
Processor: x86 family 6 Model 15 Stepping 2
Processor Speed: 1662 MHZ
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 945 Express Chipset Family
Video BIOS: 1343
Current Graphics Mode: 1280 by 1024 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1
* Digital Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 14.0 inches
Vertical: 11.0 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (67 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
832 by 624 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (70 Hz)
1024 by 768 (75 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 ff ff ff ff ff ff 00 22 64 c6 13 0e 04 00 00
06 11 01 03 81 26 1e 78 2a c5 56 a4 54 4a 9d 24
14 4f 54 bf ef 80 81 80 71 4f 81 40 01 01 01 01
01 01 01 01 01 01 30 2a 00 98 51 00 2a 40 30 70
13 00 78 2d 11 00 00 1e 00 00 00 ff 00 37 30 36
47 4a 33 4a 59 30 31 30 33 38 00 00 00 fd 00 32
4c 1e 53 0e 00 0a 20 20 20 20 20 20 00 00 00 fc
00 4a 43 31 39 39 44 0a 20 20 20 20 20 20 00 53
* SDVO Encoder Report *
** Encoder 1 **
Vendor ID: Silicon Image
Device ID: 170
Device Revision: 3
Major Version: 1
Minor Version: 1
* Other names and brands are the property of their respective owners.
Any ideas on how to rectify this? Using two different resolutions is killing my eyes...
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
Video BIOS: 1343
* Digital Display *
Gamma Value: 2.20
640 by 480 (60 Hz)
640 by 480 (67 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
832 by 624 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (70 Hz)
1024 by 768 (75 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 960 (60 Hz)
Raw EDID:
** Encoder 1 **
Device ID: 170
Device Revision: 3
Major Version: 1
Minor Version: 1
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
