My server information is as follows. And the license information is followed. I don’t know why it does not recognize my license. Could you please help me to solve this problem?
Error
Error: A license for FCompL is not available now (-15,570,115).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
1. Trusted Storage
** 2. /opt/intel/composer_xe_2015.2.164/licenses/COM_L__FOR_XXXX-XXXXXXXX.lic
** 3. /opt/intel/licenses/l_XXXXXXXX.lic
** 4. /home/song/intel/licenses
** 5. /opt/intel/composer_xe_2015.2.164/bin/intel64/../../Licenses
** 6. /home/song/Licenses
** 7. /Users/Shared/Library/Application Support/Intel/Licenses
** 8. /opt/intel/composer_xe_2015.2.164/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
ifort: error #10052: could not checkout FLEXlm license
Server information
[root@tel02 bin]# /sbin/ifconfig eth0
eth0 Link encap:Ethernet HWaddr 00:1E:4F:2C:5E:00
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:18 Memory:d6000000-d6012800
[root@tel02 bin]# hostname
tel02.localhost.localdomain
- Tags:
- Development Tools
- Intel® License Manager for FLEXlm*
- Intel® Software Development Products Registration Center
This sort of question is probably best handled by Premier Support but I'll have a go.
Things to check:
- The licence being used by the client machine is correct (I think it should just contain the server machine name and the port number)
- The client can see the server on the network - does it respond to 'ping'?
- The FlexLM licence server is running on the server machine. Perhaps the server machine was restarted and the licence server did not restart for some reason.
If all these checks pass then you should monitor the log file in the installation directory of the licence server - a line added everytime the licence server recieves a request for a licence. Monitor this file in real time (tail -f <logfile>) to make sure requests are being received.
Hi, Sang
This is a public forum. Please do not paste license related information in the forum threads.
I have edited your original post and removed license related information.
Things for you to check:
1. Have you started Intel license manager on your license server: tel02.localhost.localdomain?
For more information on how to install and setup Intel Flexlm license manager, please refer to below article:
2. After install license manager, you will find lmstat from installation package, run
# ./lmstat -a
To get license server status and send us the output.
