Software Archive
Read-only legacy content
ACPI Error in Linux kernel boot
JONG_L_
CRB(with E3845), the firmware built from Intel Firmware Engine(IFE), and 4.2.3 kernel showed ACPI Errors below while COTS(with E3845), its firmware, and 4.2.3 kernel(very same kernel) didn't show any ACPI Error. What are these errors? How can I fix?
[    0.111143] ACPI Error: [TPME] Namespace lookup failure, AE_NOT_FOUND (20150619/psargs-359)
[    0.111154] ACPI Error: Method parse/execution failed [\_SB_.TPM_._STA] (Node ffff8800768917a8), AE_NOT_FOUND (20150619/psparse-536)
[    0.111193] ACPI Error: [TPME] Namespace lookup failure, AE_NOT_FOUND (20150619/psargs-359)
[    0.111201] ACPI Error: Method parse/execution failed [\_SB_.TPM_._STA] (Node ffff8800768917a8), AE_NOT_FOUND (20150619/psparse-536)
[    0.132503] ACPI Error: [TPME] Namespace lookup failure, AE_NOT_FOUND (20150619/psargs-359)
[    0.132514] ACPI Error: Method parse/execution failed [\_SB_.TPM_._STA] (Node ffff8800768917a8), AE_NOT_FOUND (20150619/psparse-536)
[    0.147881] ACPI Error: [TPME] Namespace lookup failure, AE_NOT_FOUND (20150619/psargs-359)
[    0.147891] ACPI Error: Method parse/execution failed [\_SB_.TPM_._STA] (Node ffff8800768917a8), AE_NOT_FOUND (20150619/psparse-536)
BrianRichardson
I will forward this to the team for investigation. Can you also run the LUV OS Image from 01.org and see if you get a similar error?
https://01.org/linux-uefi-validation
You may see other warnings/errors, but I'm primarily interested in seeing if the LUV kernel has the same error. Thanks.
BrianRichardson
Jong: please verify the version of the MinnowBoard Max project you are using with Intel Firmware Engine (1.0.0, 2.0.0 or 2.1.0)?
JONG_L_
Hello Brian,
I have been using 2.0.0. I wasn't aware of new version 2.1.0. I will try 2.1.0 shortly.
Do you think the ACPI Errors will go away when I upgrade to 2.1.0?
JONG_L_
Hello Brain,
According to the 2.1.0 release note(http://firmware.intel.com/sites/default/files/Release%20Notes%20MinnowBoard%20Max%202.1.0.pdf) it looks like only two changes(see below). Other than Branding is there difference between 2.0.0 and 2.1.0?
NEW FEATURES AND CHANGES
1. See New Features and Changes for release 2.0.0
2. This release has changes for Trademark and Branding strings.
JONG_L_
Hello Brian
LUV kernel has the same errors. See below. I've attached the full serial console output, luv-live-imagelog.txt. What are these errors? How can I fix?
[    1.221189] ACPI Error: [TPME] Namespace lookup failure, AE_NOT_FOUND (20150410/psargs-359)
[    1.230678] ACPI Error: Method parse/execution failed [\_SB_.TPM_._STA] (Node ffff8800764987a8), AE_NOT_FOUND (20150410/psparse-536)
[    1.244364] ACPI Error: [TPME] Namespace lookup failure, AE_NOT_FOUND (20150410/psargs-359)
[    1.253804] ACPI Error: Method parse/execution failed [\_SB_.TPM_._STA] (Node ffff8800764987a8), AE_NOT_FOUND (20150410/psparse-536)
[    1.645060] ACPI Error: [TPME] Namespace lookup failure, AE_NOT_FOUND (20150410/psargs-359)
[    1.654528] ACPI Error: Method parse/execution failed [\_SB_.TPM_._STA] (Node ffff8800764987a8), AE_NOT_FOUND (20150410/psparse-536)
[    2.258558] ACPI Error: [TPME] Namespace lookup failure, AE_NOT_FOUND (20150410/psargs-359)
[    2.268047] ACPI Error: Method parse/execution failed [\_SB_.TPM_._STA] (Node ffff8800764987a8), AE_NOT_FOUND (20150410/psparse-536)
JONG_L_
Hello Brian,
While looking at the luv-live-imagelog.txt(attached in previous one), I found a critical failure like below:
summary        ;SUM Critical failures: 1
summary        ;SUM  method: Detected error 'Not found' when evaluating '\_SB_.TPM_._STA'.
It looks like related to the original issue based on the "\_SB_.TPM_._STA". CRB doesn't have TPM. Can I disble TPM in IFE? If yes, how?
JONG_L_
Hello Brian,
Is there any update? I'm still waiting for your answer since we are blocked by this issue. Thank you.
JONG_L_
Hello Brian,
For your information I tired 0.84 firmware from https://firmware.intel.com/projects/minnowboard-max on both CRB(RC10) and MinnowBoard MAX. None of those had the '\_SB_.TPM_._STA' error. I think the firmware built from the Intel Firmware Engine had some problem. What do you think?
BrianRichardson
We're investigating the 0.84 codebase differences already. There may be some delay on our end due to the Christmas holiday, but I'll keep you posted. Thanks.
JONG_L_
Hello Brian,
Is there any update? When do you think the issue will be resolved? Thank you.
