Software Archive
Read-only legacy content
17060 Discussions
ALLOCATABLE User-Defined Types and Strange Behavior
michael-a-carr
I have something similar to following code:
--- type.f90 ---
MODULE MTYPE
TYPE NEWTYPE
  INTEGER, ALLOCATABLE :: N(:)
END TYPE
END MODULE
--- subrt.f90 ---
MODULE MSUBS
CONTAINS
SUBROUTINE SETUP(a)
  TYPE(NEWTYPE), INTENT(OUT) :: a
  ALLOCATE(a%n(1000))
  a%n = 0
END SUBROUTINE
END MODULE
--- main.f90 ---
PROGRAM TEST
USE MTYPE
TYPE(NEWTYPE) :: a
CALL SETUP(a)
END PROGRAM
When I run this program, it works fine until I return from the subroutine. When that happens, the array I allocated in the subroutine contains random values. Does the ALLOCATE command have scope in this case? i.e. Do I have to allocate in the outermost program unit or can I allocate in a subroutine like this?
Thank you,
Michael Carr
Intel_C_Intel
After inserting the line USE MTYPE in module MSUBS and USE MSUBS in program TEST so that the above compiles, it looks like the first few elements of a%n are incorrect. Compaq just put this allocatable components stuff in their compiler and they don't have all the kinks worked out yet. You should send them a bug report when you see misbehavior like this. Probably the above would work if you used the F95-compatible method of a pointer component rather than an allocatable component.
