Software Archive
Read-only legacy content
About vectorization performance on Coprocessors
Matara_Ma_Sukoy1
Hi all,
I just want to confirm something and ask a quick question. In order to benefit from vectorization to full extent, data should lay in memory in a successive way. I am working on sparse matrix vector multiplication in which I do something like this;
[cpp]
for(int i = 0; i < nnz; ++i)
    y = val * x[colInd];
[/cpp]
here I access val array sequentially but this is not necessariliy true for x vector.
  • If I am not accessing both arrays sequentially I am giving away additional speed up I will get otherwise right?
  • Will using a notation like "x[colInd]" affect vectorization even if it I was accessing x entries in a successive way (and result in a performance loss)?
Your thoughts are always welcome.
Matara Ma
Sumedh_N_Intel
Yes, in general, you do get a better performance if your data is aligned and the memory accesses are sequential. Hence, you may see performance gains if you access both arrays sequentially. Also, indirect memory references are costly and lead to inefficient code. You can find more about this in the following article: http://software.intel.com/en-us/articles/fortran-array-data-and-arguments-and-vectorization
There are a number of other Best-Know-Methods (BKMs) for vectorization that can be found at http://software.intel.com/en-us/articles/vectorization-essential. Other compiler BKMs can be found at http://software.intel.com/en-us/articles/programming-and-compiling-for-intel-many-integrated-core-architecture
I hope this helps.
